Author: Subject: Removable Panels for SVA
greggors84
posted on 6/6/06 at 04:23 PM Reply With Quote
Hi
Do any panels need to be removable for SVA? Will he ask me to remove the tunnel cover or boot panel?
Neither are too hard to get off, just a bit of a pain to do and it took me ages to get the trim to stay on the boot panel while i was putting it on.
Chris
The Magnificent 7!
flak monkey
posted on 6/6/06 at 04:29 PM Reply With Quote
If its permanently fixed he cant ask you to remove it. They will use mirrors to see the bits that are hard to see normally.
If you have pics of things you think he might ask about then take those, might save a lot of time.
Sera
http://www.motosera.com
DIY Si
posted on 6/6/06 at 04:44 PM Reply With Quote
How would this work with a semi-permanently fixed floor panel? If it's bolted in, could he ask me to remove sections of it? Such as the rear undertray?
nitram38
posted on 6/6/06 at 05:23 PM Reply With Quote
It is a good idea to provide photos of any hidden seatbelt mounts otherwise these can be a failure.
tri
posted on 6/6/06 at 09:11 PM Reply With Quote
we did but a letter sorted that out but was a pain to wait so take lots of pics just to make sure he can see every last bit of the car
muzchap
Do the transmission tunnel covers have to be permanently fixed?
Mine are pushed on with massive thick foam and held on by the gearstick and handbrake levers?
It's impossible for them to lift off?
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
