Author: Subject: Did i buy the right fuel hose for SVA ?
marcotuinenburg
posted on 7/6/06 at 06:39 PM Reply With Quote
Last week i bought 5 meter of normal fuel hose, it's a clear sort, just the normal kind of hose.
Yesterday a friend askes me if this was the righr one for SVA specifications, are there any special specifications for the fuel hose i would like to use ?
Thanks,
Marco
donut
posted on 7/6/06 at 06:58 PM Reply With Quote
I'mm 99.9% sure it has to me marked for use for fuel on the side so the stuff you have bought will not pass SVA. The stuff you want is black 8mm fuel tubing marked as such.
Anyone please correct me if i'm wrong.
Peter M
posted on 7/6/06 at 07:13 PM Reply With Quote
And this is what is needed printed on hose for UK SVA. British standard BS Au108/2-L4/C4/R
[Edited on 7/6/06 by Peter M]
my previous cars
my westfield build
marcotuinenburg
posted on 7/6/06 at 07:18 PM Reply With Quote
i made a picture of the side of the fuelhose.
tks
posted on 7/6/06 at 07:21 PM Reply With Quote
GENERAL purpose
sounds for me like a fail..
its more for water and pumps etc..
Tks
marcotuinenburg
posted on 7/6/06 at 07:30 PM Reply With Quote
well, the man at the parts shop sold me the wrong hose.
Where can i buy the correct fuel hose online ?
Thanks for the advice.
Marco
donut
posted on 7/6/06 at 07:31 PM Reply With Quote
Can't you take it back and get him to change it for the correct stuff?
marcotuinenburg
posted on 7/6/06 at 09:49 PM Reply With Quote
if i can change it for flexible copper line will that be a good alternative ?
Marco
ReMan
posted on 7/6/06 at 09:57 PM Reply With Quote
Marco
Yes, but you will still probably need some "proper" rubber or braided fuel hoze for the ends wherr it joins the pump/engine.
You may find you can get copper microbore plumbing pipe very cheaply.
Chippy
posted on 7/6/06 at 10:00 PM Reply With Quote
If this is for your main fuel line, tank to engine, copper is just fine. Just make sure that any hoses connecting from it to tank, and carb are the correct type hose, "ie" marked as such. atb Chippy.
Reman, just beat me to it
[Edited on 7-6-06 by Chippy]
Avoneer
posted on 7/6/06 at 10:07 PM Reply With Quote
Clear hose is a fail as it becomes brittle when exposed to petrol.
You can buy the rubber stuff at most places like Halfords etc.
Pat...
ReMan
posted on 8/6/06 at 09:59 AM Reply With Quote
Pat...
Would that be Halfjords?
