donut
posted on 9/6/06 at 12:53 PM |
Another dash radius question
I'm using some door trim rubber for a Mini that just pushes onto the bottom of the dash. Is this going to be ok or does it need to be
permanantly fixed?
Marcus
posted on 9/6/06 at 01:38 PM |
SVA bloke said mine had to be permanently fixed. Superglue did the job, dash re-covered after SVA
Marcus
Because kits are for girls!!
donut
posted on 9/6/06 at 02:29 PM |
I would'nt have said superglue was a permanent fix but hey if it works!!
jos
posted on 9/6/06 at 03:05 PM |
cover over the dash & door trim with vinyl, that way theres no way of taking it off & is permanat for the purposes of the sva test
donut
posted on 9/6/06 at 03:16 PM |
My dash is already fitted and ready to go so i need to permanantly fix something. I don't want to rivet anything on as that will leave holes
after.
hmmm
Deckman001
posted on 9/6/06 at 03:41 PM |
What about that black silicon/glue stuff i gave ya, that'l stick the proverbial to a blanket !!
Jason
donut
posted on 9/6/06 at 03:44 PM |
Yeah but in needs to come back off after and that stuff (good as it is) will leave a hell of a mess!!
shortie
posted on 9/6/06 at 04:47 PM |
I stapled mine on, worked a treat, but obviously the dash has to be ply!
donut
posted on 9/6/06 at 05:01 PM |
Mines ally and carbon fiber looky likey fiberglass. I think i'm going to have to rivet something on there and sort the holes out later.
RazMan
posted on 9/6/06 at 05:29 PM |
I find that hot glue is as permanent as you need it to be. It holds pretty much anything in place and when you want to remove it just carefully peel
it away - it doesn't leave a mark.
Raz
