Author: Subject: Is 6 full turns enough for SVA?
stevec
posted on 28/6/06 at 07:43 PM Reply With Quote
Is 6 full turns of a wheel nut enough to satisfy the SVA fella,
I have 8 full turns on the rear but only 6 on the fronts!!
I have tried the search option in the forum for a topic but failed to find, I am sure there was a thread on this subject not long ago.
Thanks,
Steve.
[Edited on 28/6/06 by stevec]
Danozeman
posted on 28/6/06 at 08:11 PM Reply With Quote
That sounds too few to me. Can u see any of the thread poking throu or do u have capped nuts??
Dan
indykid
posted on 28/6/06 at 08:24 PM Reply With Quote
yes, the minimum i've ever heard required for sva is 6 turns.
you only get 6 turns in an m12 nut, just to put it into perspective.
tom
stevec
posted on 28/6/06 at 08:25 PM Reply With Quote
The studs do not show through the nuts but the chrome nuts are almost twice as deep as the original Ford ones.
Steve.
zetec7
posted on 28/6/06 at 11:01 PM Reply With Quote
If it were me, I'd be looking for longer studs...I'd only trust that little engagement if my granny were driving. Maybe not even then! On open nuts, I like to have at least 1-2 threads showing proud of the nut...
Dave J
posted on 29/6/06 at 08:26 AM Reply With Quote
Six turns is not enough. You'll only be using about 9mm of thread length. On a 12mm stud you need to be screwed on at least 12mm thread length.
Change your studs for longer, it's an easy job, the studs are cheap.
Be safe.
Dave
simonk
posted on 29/6/06 at 01:43 PM Reply With Quote
Been going through the same question. The Ultralites on my Viento leave me with only 5 full turns so have measured up for new studs. Merlin Racing do studs in a few lengths and it looks like their 15/8 studs will give me enough engagement.
Best of luck
Simon
mad4x4
posted on 29/6/06 at 05:16 PM Reply With Quote
I was advised today to use original ford nuts on the front to make them fully comply. HE said the aftermarket ones were "borderline" he looked at how far the bolt came through the nut and not the number of truns.
Bolt should be "most or the way" through the nut at minimum.
Scot's do it better in Kilts.
