rayward
| posted on 17/7/06 at 12:03 PM |
Top Harness Mounts????
does this look OK, or will i have to raise the top mount???
  top harness
  top harness2
Ray
| posted on 17/7/06 at 12:05 PM |
You'll probably have to do the measurements from the seat to be sure... you might be OK as you've got GRP seats.
On that topic, you'd better put some edging strip round the harness holes, as the tester may take a dislike to that fairly sharp edge.
rgds,
Surrey Dave
| posted on 17/7/06 at 12:06 PM |
Depends where they are in relation to the seat squab/ base hieght.
But with unupholstered seats you should be able to wangle it.
mad4x4
| posted on 17/7/06 at 12:43 PM |
I'd put edging on the seat hole as it may deemed sharp for the seatbelt and may lead to cutting or chaffing.
Scot's do it better in Kilts.
JohnN
| posted on 17/7/06 at 06:39 PM |
The edges of the seat belt shackles themselves were deemed too sharp at Shrewsbury VOSA , could injure somebody if you backed into them. 100mm sphere
avoidance measures required to avoid contact
wicket
| posted on 18/7/06 at 11:14 AM |
There is a diagram in this thread showing SVA dimensional requirements
http://www.locostbuilders.co.uk/viewthread.php?tid=19802
