posted on 19/7/06 at 01:11 PM |
SVA queries
Tried searching on this, but....
What does the SVA man look for around the pedal area?
Nick
BKLOCO
posted on 19/7/06 at 01:19 PM |
1 loud pedal. (go)
1 soft pedal (stop)
1 other on the left (not sure what that one's for.)
Seriously though.
Nothing as far as I know.
As long as ther are secure and fit for purpose you should be ok.
Oh and brake and clutch must be non slip (not bare metal)
[Edited on 19-7-06 by BKLOCO]
posted on 19/7/06 at 02:36 PM |
What about sharp edges?
posted on 19/7/06 at 03:31 PM |
AFAIK - as long as it's not blatantly a bad build with SHARP EDGES you'll be ok. Just file round edges to remove burrs...
Alan_Thomas
posted on 19/7/06 at 04:20 PM |
Nick
I believe you cannot get away with an adjustable balance bar if you are using twin master cylinders. Balance bar must be locked in position.
- Alan
posted on 19/7/06 at 05:43 PM |
cheers guys!
no balance bar in my set-up, just bog standard Sierra m/c
Chippy
posted on 19/7/06 at 08:16 PM |
Pretty sure that you have to have non slip pedals, either propper rubbers, or some heavy grit sanding cloth. I used a bit of a worn belt, from a belt
sander on my throttle, no probs. Regards Ray.
