darrenga
posted on 16/8/06 at 03:56 PM |
p cliping fuel line
how close together do you p clips have to be on your fuel lines for sva
BKLOCO
posted on 16/8/06 at 04:19 PM |
There is no specified distance but brake lines must be clipped a max of every 300mm so I would recomend the fuel pipe is clipped in a similar fasion.
muzchap
posted on 16/8/06 at 05:13 PM |
Every 3-4 inches was what I was told...? I'm sure there are specifications and that distance meets them...
I like the idea of it being totally secured and they do check it at SVA
Good luck - I remember the satisfaction of getting all the copper bent and to shape (1 or 2 goes at it LOL) and then p-clipped in
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
omega0684
posted on 16/8/06 at 06:40 PM |
i have just checked my dax build guide and it says that fuel lines should be p-clipped no more than 9 INCHES APART!!
Stuart Walker
posted on 16/8/06 at 10:42 PM |
The bloke at my SVA (fail!!) today said 12 inches minimum, but I'm going for a lot less than that.
