theconrodkid
posted on 28/8/06 at 04:30 PM |
brake fluid level
just noticed the built in level sensor in my master cyl in not in the cap so imposible to check its opperation apart from pushing a button on the dash
which proves the bulb works.
how will mr jobsworth from the minstry of silly walks veiw this,its a genuine ford part
who cares who wins
pass the pork pies
posted on 28/8/06 at 04:44 PM |
He'll probably take the cap off.
As long as the button works it shouldn't be a problem.
theconrodkid
posted on 28/8/06 at 04:47 PM |
short of draining some fluid off there is no way to check the level switch is working
who cares who wins
pass the pork pies
jollygreengiant
posted on 28/8/06 at 05:12 PM |
If you un-screw the cap and lift it, it has the same effect as draining or taking fluid out - it lifts the sensor/float out of the fluid.
Also if you have an extra earth running off of the sensor (as per Sierra/Granada) then that when connected to the handbrake switch will do the job of
push the button to test light by pulling the hand brake on and off.
[Edited on 28/8/06 by jollygreengiant]
theconrodkid
posted on 28/8/06 at 08:02 PM |
jgg,the lid is just a lid,the float is the other side of the container,the SVA says the tester must be able to see that the float floats and the
switch works
who cares who wins
pass the pork pies
Dusty
posted on 28/8/06 at 10:17 PM |
He will have to poke the float down with a nice clean bit of wire to activate the float switch and see the dash light come on, then confirm the button
tests the same light.
jollygreengiant
posted on 29/8/06 at 04:39 AM |
switch works
Sorry I need to go to opticians again.
posted on 29/8/06 at 08:41 AM |
Yes but to do that he'll have to take the lid off, see above.
