Author: Subject: Main Beam flash
r3nuf
posted on 31/8/06 at 12:40 PM Reply With Quote
Main Beam flash
Could anyone confirm if being able to flash high beam is an SVA requirement.
Have managed to get Luego loom to operate high beam via relay, but i seem to have a problem with the flash function.
Just wondered if i have to panic over this prior to my SVA on Wednesday?!
Gary
Drive Fast....Brake Late....Take Chances
Peter M
posted on 31/8/06 at 12:45 PM Reply With Quote
No need to be able to flash headlights only that you can select main or dipped headlights.
graememk
posted on 31/8/06 at 12:54 PM Reply With Quote
so do you need to be able to flash for a mot
Just
posted on 31/8/06 at 01:52 PM Reply With Quote
No requirement for flash on MOT - only a main beam that can be switched on and off.
r3nuf
posted on 31/8/06 at 02:06 PM Reply With Quote
Thanks guys....
I will leave it as it is at the moment.
Just got to sort out the 1000 other problems i have, before wednesday, now.....
Gary
iank
posted on 31/8/06 at 02:27 PM Reply With Quote
Never found a flash on my Rover200, so unless the stalk is broken I don't believe it's a requirement.
posted on 31/8/06 at 08:59 PM Reply With Quote
this seems to be a fairly common problem these days.
