Author: Subject: Fitting hydraulic handbrake
Iain Campbell
posted on 16/5/03 at 06:36 AM Reply With Quote
Fitting hydraulic handbrake to the car....
how does this effect the SVA?
roadgoing/racing car
posted on 16/5/03 at 07:28 AM Reply With Quote
If you are talking about the hydraulic handbrake that works in the same circuit as your regular brakes, then it means that you will fail...
The handbrake (secondary brakes) has to be a totally independent system from the normal system (primary brakes) - half-remembered quote from the SVA manual.
DJ
Wadders
posted on 16/5/03 at 02:15 PM Reply With Quote
I too was going to use hydraulic handbrake calipers, totally seperate from main hydraulic system, but then i found out that for MOT you have to have a mechanical system so after wasting hours making brackets e.t.c iv'e gone back to a cable system.
Spoilsports
DJ [/quote
[Edited on 16/5/03 by Wadders]
Iain Campbell
posted on 16/5/03 at 06:01 PM Reply With Quote
Thanks for the info, saves any more time
playing around on the hand brake setups.
