GeoffB
posted on 14/9/06 at 04:12 PM |
Can i cover my braided hoses..?
My front brake hoses come quite close to the wishbones but dont actually touch on full lock. Sods law will be that on the sva test they will probabley
touch.
Can i split a length of petrol hose and cover the braided hose in the vunerable areas and tie wrap it on..so even if they do touch they will not make
contact
Geoff
chrisj
posted on 14/9/06 at 04:18 PM |
Double bag even more than that I am afraid.
They want to make sure their is no chance of chafing.
Cover the pipe with the fuel pipe (this is the inner sleeve), and then use some of the cable tidy you have lying around to create the outer sleeve and
secure with cable ties.
This satisfied my examiner.
nitram38
posted on 14/9/06 at 06:32 PM |
Mine are wrapped in spiral wrap and they passed.
posted on 15/9/06 at 07:24 AM |
Ours are wrapped in clear heat shrink...
DarrenW
posted on 15/9/06 at 02:39 PM |
i used spiwrap on mine. No idea why though!!!
When fitting the fronts i managed to put a twist in them so that on full lock they twist themselves slightly and dont touch anything. Its a standard
technique for these sorts of cars.
Others have found a way to clip the hose close to (but not touching) the wishbones.
Im surprised the double sleeving idea is allowed. My tester was quite specific when he said they must not touch anything on either lock. He failed my
handbrake cables cos they just say touched some bodywork underneath when the handbrake was applied. Had to remove some of the bodywork (hidden by
arch) and clip them back better.
