Author: Subject: x/flow 1300 dizzy problem
Iain Campbell
posted on 17/5/03 at 12:38 PM Reply With Quote
I'am running a 1300 (well building)
and the dizzy will not fit under the twin 40's, it catchs the inlets,it's running a lumenition setup with the exits for the leads up the way, and the cap is held on with clips, it there another cap with side exit for the leads with clips?
help needed.
Thanks.
scutter
posted on 17/5/03 at 01:27 PM Reply With Quote
The cap you want is available from your ford dealer, it's part of the motorcraft range. Ask for a Fait strada super 75, motorcraft part number 5005566.
It apparently fit perfectly on to a X-flow dissy.
All the best Dan.
Iain Campbell
posted on 17/5/03 at 04:29 PM Reply With Quote
1300x/flow problem
Hi.
That's great!! is it a side exit one?
I'll be over to Halfords next week, the joy of living in Scotland, it takes days to get anywhere.
[Edited on 17/5/03 by Iain Campbell]
scutter
posted on 17/5/03 at 07:35 PM Reply With Quote
Got the information out of the Wallage book on tuning X-flows, so should be good, and yes it's the side exit one.
Now you're just trying to cheer me up as I'm moving up to Leuchars the first week in June.
Glad to help Dan.
steve m
posted on 17/5/03 at 09:11 PM Reply With Quote
I will have a look in my Xflow rebuid manual, but i am sure that the 1300 lump with twin 40 will require the inlet manifold to be taken off for any work to be done on the distributer (ie taken out)
even on the 1600 with side entry cap its all a tight fit, and the 1300 is about an inch shorter in the block
steve
Stu16v
posted on 17/5/03 at 10:48 PM Reply With Quote
And dont forget there is two different types of dizzy fitted to the xflow, Bosch and Fomoco (IIRC). What colour is your present cap?
barrie sharp
posted on 21/5/03 at 03:35 PM Reply With Quote
anyone!! can you help.
i have brought a fiat strada dizzy cap and it does not fit my dizzy. are there more than one type dizzy for the 1300 ford escort (76) it has a black cap if that is any help and if i have a different one from everyone else can i get a side entry cap for it
thanks
the cars looking good" a blind man would be pleased to see it"
''stop press'' the blind mans seen it said "it felt ok"
scutter
posted on 21/5/03 at 03:53 PM Reply With Quote
Sorry for supplying duff info, it's how it came out the tuning book.
All the best Dan.
theconrodkid
posted on 21/5/03 at 04:28 PM Reply With Quote
barrie you got a fomoco dizzy you need a bosch dizzy to fit yr cap,fitted to fiesta1100 and escorts with same engine
who cares who wins
pass the pork pies
barrie sharp
posted on 21/5/03 at 07:24 PM Reply With Quote
cheers conrod. I dont suppose you know of any going cheep.
or do you know if i can get a cap for the formoco dizzy
thanks
[Edited on 21/5/03 by barrie sharp]
david walker
posted on 21/5/03 at 09:47 PM Reply With Quote
Junk the Fomoco dizzy. They wear and they are points only. You need the electronic one as Conrod has said from the Valencia engined Fiesta or Escort.
Any breakers will sell you on. Up here in the near north they can be had for about 15 quid. When you get it obtain a short bit of the loom with the plug on also.
As has already been said, on a 1300 in a book type chassis, using sidedraft carbs, it will be totally inaccessible!
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
Peter Brooker
posted on 23/5/03 at 07:09 PM Reply With Quote
1300crossflow dissy
I am also running 1300 crossflow but with single 40dcoe If its any help to any one I managed to shorten a Bosch dissy from the fiesta valencia engine ,actualy esier than it sounds if you have access to a lathe you also need to mount the amplifier remotely and use the fiat side entry cap .Much cheeper electronic ignition than Luminition set up.If anyone need more info please email
