Author: Subject: MK SVA question
stevec
posted on 22/9/06 at 09:28 PM Reply With Quote
MK SVA question
Are the chassis box section tubes in the drivers and passenger footwell sides radiused enough for SVA or do I need to cover them.
Thanks.
Steve.
ReMan
posted on 22/9/06 at 10:12 PM Reply With Quote
No problem for me Steve, not even looked at/mentioned
cColin
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
stevec
posted on 22/9/06 at 10:35 PM Reply With Quote
Colin.
Did they let you use silicon on the famous Indy dodgy side join?
And I notice I have lagged my Can in a similar way.Should keep the little tinkers ball out of the edges,
Your Car looks cool.
stevec
posted on 22/9/06 at 10:39 PM Reply With Quote
Originally posted by CaLviNx
Hi
measure them to check !!! a fail of an interior design feature or fitting is
Section 6"interior fittings" of the SVA manual
a. has a rough or sharp edge or a projection of 3.2mm or more likely to cause injury ie having a radius of curvature less than 2.5mm
b. has a projection of less than 3.2mm,
i. the height of which is more than half its width having a radius of curvature of less than 2.5mm.
ii. the height of which is not more than half its width the edges of which are not blunted
Mark, I read that bit and my head still hurts.
I will have to stop drinking for a day or two and read it again.
Thanks.
ReMan
posted on 22/9/06 at 11:14 PM Reply With Quote
Originally posted by stevec
Colin.
Yea, blob of clear silicon OK, though I started out with a neat piece of duck tape just to take the edge off.
You should'nt have a problem, it looks great in the pics.
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
ReMan
posted on 22/9/06 at 11:36 PM Reply With Quote
BTW do you have a date yet?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
stevec
posted on 23/9/06 at 09:10 AM Reply With Quote
Mark.
Thanks for that link.
I reckon I will have to put something over it.
I have a sheet of ABS plastic I think I will cut two pieces and cover the whole thing, Remembering to make sure there are no edges on the sheets !!!!
Thanks again.
Steve.
stevec
posted on 23/9/06 at 09:12 AM Reply With Quote
No Date yet.
Before christmas I hope.
Hammerhead
posted on 23/9/06 at 10:11 AM Reply With Quote
hellfire has a neat solution to the 'dodgy side panel' check his website
stevec
posted on 23/9/06 at 04:22 PM Reply With Quote
Yep they did a great job of the join.
Clever lot arnt they?
