RobBrown
posted on 28/9/06 at 09:13 PM |
Is Chequer plate SVA friendly?
As title suggests, if I have this on the transmission tunnel , does the raised stripes class as not correctly radiused edges?
Rob
ReMan
posted on 28/9/06 at 09:22 PM |
Technically its probably OK as the raised bits arn't raised enough to need radii more than blunt edges, but it might cast doubt as some edges
could be percieved as sharp??
www.plusnine.co.uk
oliwb
posted on 29/9/06 at 01:01 PM |
As mentioned technically should be OK but SVA man may not see it this way.....bit of an odd choice for transmission tunnel top though...what made you
choose that? Oli.
RobBrown
posted on 29/9/06 at 05:15 PM |
I currently have ali corners on the tunnel(see
here), but suspect that these will fail on radius grounds at my SVA next week, so whilst looking around in B & Q, came across nice radii
edged corner strips, but it has chequer plate design on it. I'm just trying to think of neat way or replacing the existing ali. It is also
functional in that it holds both edges of the carpet
Rob
ReMan
posted on 29/9/06 at 05:37 PM |
I see! Disd wonder myself about the aesthetics too! (No offence to anyone who alredy has a checkerplate transmision tunnel though!)
If its only temporary and the ali corners are going back on, how about some wood moulding?
B=Q do a right angle about the same size, with a smooth external angle?
www.plusnine.co.uk
caber
posted on 29/9/06 at 06:07 PM |
Very Rolls Royce ! remember to put cup washers on brass screws with the slot lned up and 12 coats of varnish sanding down between each coat
Caber
