Author: Subject: Securing Brake lines
nib1980
posted on 30/9/06 at 09:43 AM Reply With Quote
Hello all,
hopefully a quick one, can you use plastic p-clips for fuel and brake lines, or do you have to use rubber lined metal ones?
many thanks
RazMan
posted on 30/9/06 at 09:54 AM Reply With Quote
Either is fine but I would use the rubber lined stainless version.
Raz
posted on 30/9/06 at 09:58 AM Reply With Quote
Plastic ones are fine for both fuel and brake pipes, used by most car manufacturers, quick, cheap and reliable. Can use one clip to hold both pipesjust make sure you secure them at about 9" apart for SVA
nib1980
posted on 30/9/06 at 10:31 AM Reply With Quote
Many thanks all
the_fbi
posted on 30/9/06 at 10:32 AM Reply With Quote
Mark, whats the other half of the fitting for?
Is it a spacer to space the pipe from the chassis or do you drill the holes oversize then put the bush in or?
ta
Chris
wicket
posted on 30/9/06 at 11:06 AM Reply With Quote
The shouldered bush goes in the drilled hole & the the pipe clip is tapped into the bush. The pipe clip has a larger diameter at the end, so its swages out the bush on the inside of the chassis tube.
robinj66
posted on 30/9/06 at 08:31 PM Reply With Quote
Mark
Where do you get them there thingys from?
RazMan
posted on 30/9/06 at 10:36 PM Reply With Quote
Here's another alternative (in a fetching shade of blue) from Rally Design Rescued attachment pipe separator.jpg
Raz
