MK9R
posted on 21/5/03 at 11:55 AM |
pre 1995
state that my engine is 1994 (new engine number if re conditioned) will i not need to have a cat on it, and will it get through emmisions without the
lamda/carb thingy?
(posted in BEC aswell)
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
zetec
posted on 21/5/03 at 12:47 PM |
Pre "95 (changeover sometime mid "95) at the moment does not need a Cat. I think the reason we are able to get the non cat test is that
the SVA book says that vehicles fitted with engines built after "92 cat law, but before "95, have to be tested to the limits listed in the
emission test book. As there does not appear to be many, if any, kit cars listed they are to be tested to the pre "92 levels. This means any
properly tuned engine should pass easily on carbs without a cat. The only problem is that you will need proof of the engines age, suspect a note
written on the back of a fag packet by the local breaker may not be enough. I think also the MOT test may have changed for cars registered after the
SVA test was introduced, and will follow the same lines. As with everything SVA worth checking before building.
