Author: Subject: Windscreen, Heater and SVA
The Doc
posted on 29/10/06 at 10:56 PM Reply With Quote
My plan is to SVA the car minus windscreen and add this afterwards. I have already made provision for a heater, wipers etc.
My question is:
Assuming I blank off holes with grommets etc. will it matter that I have the wiper motor, heater box etc. in situ or will these be seen as non-functioning equipment? I'd rather have them in place to avoid the need for going back into the scuttle later.
I would guess/hope that the SVA man would simply ignore these if there is no screen fitted.
Anyone else do this?
TA
Mike
Simon
posted on 30/10/06 at 12:13 AM Reply With Quote
Mike,
If you have no windscreen, the rest (demist/wipers) become irrelevant as far as the test is concerned.
As you've already gone to the trouble of sorting wipers/demist, I'd have thought the glass would have been the least of your worries - just make sure it's correctly marked.
Simon
ch1ll1
posted on 30/10/06 at 08:01 AM Reply With Quote
do you need a heater if you have an electric front screen?
Peter M
posted on 30/10/06 at 08:30 AM Reply With Quote
No heater required if you have a heated front screen.
