Author: Subject: Suspension arm boots
davrus
posted on 22/11/06 at 09:44 PM Reply With Quote
Hi again
What do you all use to cover the front suspension arm mounts and where can i get them from
DarrenW
posted on 22/11/06 at 10:01 PM Reply With Quote
Do you mean the bolt heads that secure the wishbones - nut covers.
or the steering arms - split conduit cable tied on.
If you try a search there will be a few pics from old posts.
Dont forget headlight lens securing screws may need to be covered.
davrus
posted on 22/11/06 at 10:20 PM Reply With Quote
yes the bolts that hold the wishbones on
posted on 22/11/06 at 10:25 PM Reply With Quote
Built some bulges onto the side of my nose cone to cover top wishbone bolts. Used some covers that I got from ebay for the top ball joints and nut covers for the lower . Radio controlled car tyres for the spring seat/ adjustor and electrical conduit shrouds for the track rod ends
DavidM
posted on 23/11/06 at 01:04 PM Reply With Quote
I used a bulkhead grommit to cover the bracket, held in place with a nut cover.
Proportion is Everything
