Author: Subject: SVA requirements? Reverse Light....
nib1980
posted on 17/12/06 at 10:38 AM Reply With Quote
Morning all,
hopefully a simple question.
Do I need a reverse light for SVA / MOT?
Can it be operated by a manual switch if nessercary?
Many thanks
posted on 17/12/06 at 10:46 AM Reply With Quote
No, not a requirement for either test.
BUT - if you do fit one, it must be either automatic (i.e. from a gearbox switch) or have a tell-tale light on the dash if switched manually.
...or so I believe!
No
You don't need one. If you have a manual one it must have a tell tale on the dash. There is a limit on the bulb size as well, something like 21 watts.
russbost
posted on 17/12/06 at 01:53 PM Reply With Quote
21 Watts is correct, agree the above
Simon
posted on 24/12/06 at 01:19 AM Reply With Quote
As above, I didn't bother with any for two reasons. Couldn't decide where to put it, and the rear of car is about 2 feet from your head, so your rear side lights should provide enough illumination.
Simon
