| posted on 21/12/06 at 10:37 AM |
exhaust mount shield
someone was aksing me about this - just got round to tkaing the photo
the mounting bracket/bolt is not SVA friendly on a lot of exhausts; here is my propsed solution.
An curved ali strip with a bit folded back on itself (so is like s 'T' with curved top) for the bolt is fitted; 8 mm round tube on the edges
- photo should say it all.
Will see if it gets through retest that I hope to do early in the new year.
[Edited on 21/12/06 by 02GF74]
Marcus
| posted on 21/12/06 at 10:58 AM |
That's very similar to mine. Should be fine.
Marcus
Because kits are for girls!!
tks
| posted on 21/12/06 at 12:00 PM |
mhh
i have used a rounded nut..
it has the same shape as a bolt/nut cap
in stainless offcourse
would that be enough??
Tks
| posted on 21/12/06 at 12:03 PM |
don't thnk so - it is the exhaust bracket edges are a problem too - unless the shere doesn't contact them.
I did put a nut cover ofthe nut for SVA 1 that I have to peel off (melted like cheese )
DarrenW
| posted on 22/12/06 at 10:18 AM |
I did something like that on mine. Curved ali, fitted u trim to the edges and bonded it on with Wurth stuff. Passed no probs. Bracket is post silencer
so doesnt get overly hot.
