rpm
posted on 29/12/06 at 01:44 PM |
headlamps
Hi all, anyone know if 4" diameter headlamps are ok for sva? i've just found some they've got main/dip beam and side light
"e" marked glass all in a nice chrome unit and only £35 each
expert
ex= a has been
spurt= a drip under pressure
stevec
posted on 29/12/06 at 01:46 PM |
Do they dip to the left, If so then I cant see why not.
rpm
posted on 29/12/06 at 01:49 PM |
don't know, but the guy says he sells them to classic car people so i suppose they're legal for british roads
expert
ex= a has been
stevec
posted on 29/12/06 at 02:14 PM |
If you have to pass SVA I would try and make sure or it could be £70 down the tubes
Steve,
[Edited on 29/12/06 by stevec]
James
posted on 29/12/06 at 02:19 PM |
If they don't dip left then chances are you won't pass SVA.
They may pass MOT but that's a different issue!
Most of the 4" ones I've seen dip down not left as they are motorbike lights.
HTH,
James
- Muhammad Ali
rpm
posted on 29/12/06 at 02:28 PM |
ok, looks like i'll have to get back to him and check that out
expert
ex= a has been
posted on 29/12/06 at 04:27 PM |
The smallest diameter SVA compliant headlights you will find anywhere, are 5.75".
The smaller diameter headlights are not SVA compliant and will almost certainly fail without extensive modifications. By all means fit them after SVA
if that's what you fancy.
If you want quality headlights or any other lights for that matter, you won't go wrong with the products that SVC supply.
SVA Website
Phil
