Author: Subject: filters
mat.price
posted on 4/1/07 at 05:58 PM Reply With Quote
filters
Dose anyone know if this air filter is SVA ok as I asked Burton power at the beginning of the week and they said that they did not know and will phone me back? Rescued attachment filter1.jpg
oliwb
posted on 4/1/07 at 06:13 PM Reply With Quote
Depends which bit of it. Back plate securing mounts prob aren't but Imagine the foam is but you might need to take off any trumpets so that they can't be felt under the foam. Basically no but then it shouldn't really matter as it shouldn't becontactable ie should be under the bonnet....how are you planning on mounting it ie got a pic? Oli.
Edit - going by replies I feel i need to clarify....IF its going on a 7 and will have a cut out in the bonnet it should be fine - but you might still need to take the trumpets off as I have heard of testers failing cars on that (mine were rubber and so OK). If however its not going on a seven and will be exposed then no it wont be sva-able but then it will be the least of your worries if thats the case.....Hope thats a bit clearer....Oli.
[Edited on 4/1/07 by oliwb]
cossiebri
posted on 4/1/07 at 06:25 PM Reply With Quote
Thats the same one as i've got for sale..
If it doesn't fit MODIFY it!!
Cheers BriF
tom_loughlin
posted on 4/1/07 at 07:11 PM Reply With Quote
Yeah, I would imagine it'll be fine - The whole of the backplate on mine is under the bonnet, and the cutout in the bonnet itself has edging trim on, and the only thing poking out of the hole is the foam bit, so I'd say very SVA friendly!
Trumpets fit fine behind my filter too - i think mine are 50mm long and I have no problems.
Hope to help mate
Tom
[Edited on 4/1/07 by tom_loughlin]
mat.price
posted on 4/1/07 at 08:47 PM Reply With Quote
This is what imp planning to fit the filter on
Just so you can get an idea of what im planning
Sorry the picture is not very good
But you can see the carbs being covered by the white tape Rescued attachment Image020.jpg
posted on 4/1/07 at 10:27 PM Reply With Quote
That should be fine for SVA. Even if there does happen to be a few sharp bits protruding, they shouldn't be too much of a problem to cover.
Phil
mat.price
posted on 5/1/07 at 08:20 AM Reply With Quote
ok people thanks for the info that is a great help
timex
posted on 5/1/07 at 01:53 PM Reply With Quote
Here is a pic of mine fit! http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=Photo-0006.jpg
timex
posted on 5/1/07 at 01:56 PM Reply With Quote
And one more! http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=9Image002.jpg
