rpm
posted on 18/1/07 at 10:14 PM |
steering wheels
i've read previous threads about covering the wheel for sva, being a tight git, whats to stop me just putting some thin foam over the metal
'arms and binding it up with something like tennis racket grip? would that satisfy sva? just a thought.
expert
ex= a has been
spurt= a drip under pressure
PAUL FISHER
posted on 18/1/07 at 10:19 PM |
Why don't you just fit the sierra one for sva
If it looked like it was meant to be permanent and the foam gave enough protection (I think the amount is stated in the manual) you should be okay....
rpm
posted on 18/1/07 at 10:41 PM |
i haven't got a sierra one and the way my dash is set up it would be a pain to put one on , any idea of the specified padding thickness?
expert
ex= a has been
Humbug
posted on 18/1/07 at 10:47 PM |
If you haven't got a Sierra item to use temporarily, what you suggest sounds good - if you put the tape on well it should look
"permanent". Just need to make sure it is padded enough to meet the regs - check the SVA book for the exact rules.
Good luck
rpm
posted on 18/1/07 at 10:50 PM |
thanks for that i'll see how neat i can be
expert
ex= a has been
RazMan
posted on 19/1/07 at 08:07 AM |
Europa sell an SVA pad for about a tenner iirc or failing that get one off an import MX5 - worked for me.
Raz
westcost1
posted on 19/1/07 at 11:38 AM |
dose it have to have any safety marks on the wheel for sva?
Marcus
posted on 19/1/07 at 12:02 PM |
No, but the boss has to be collapsible. Mountney ones aren't, Astrali ones are.
Marcus
Because kits are for girls!!
RazMan
posted on 19/1/07 at 05:52 PM |
I think you can have a collapsable boss or column
Raz
rpm
posted on 19/1/07 at 07:41 PM |
whats the web address for europa?
expert
ex= a has been
RazMan
posted on 19/1/07 at 10:51 PM |
Linky
Raz
rpm
posted on 20/1/07 at 08:09 PM |
thanks for that
DarrenW
posted on 20/1/07 at 08:35 PM |
I used collapsible column. Std wheel failed on height. When i fitted smallr aftermarket wheel SVA man made me fit collapsible boss.
