Author: Subject: Donor car
pewe
posted on 29/1/07 at 05:29 PM Reply With Quote
Donor car
I've just sold the remains of the donor car less engine, gearbox, diff , wiring etc.(purchaser is using it for trim/body spares). It's not on new type log book or SORN as it was last taxed about 10 years ago. Do I have to notify DVL A that it's been scrapped or what?
I've kept the chassis plate and the engine is as per the old logbook - what odds I can run the F27 ( I don't mind calling it a Lancia) on the same reg (B plate) and avoid SVA? Probably wishful thinking but can any of you guys come up with an angle? Thanks, Pewe
Humbug
posted on 29/1/07 at 05:51 PM Reply With Quote
No odds at all that you can avoid SVA, unless you lie and pretend it is actually the same car as the Lancia...
As far as I know you can only keep the actual original reg if you use the original chassis... not very likely, I would think .
You can get an age-related plate (e.g. if the Lancia was a D reg, then a D reg would be allocated) if at least X key parts from the donor have been used. You will need to check the DVLA website for details.
Finally, why do you want to avoid SVA (assuming you are building a "new" car)? Granted it is a bit of a hassle, but getting a car through SVA gives you some element of reassurance that it is reasonably OK - brakes, steering and fuel at least!
Good luck
EDIT: re the SORN - if you have only sold individual bits and have kept the VIN plate and V5, I think you just keep SORNing it until you go to register it.
[Edited on 29.01.2007 by Humbug]
pewe
posted on 29/1/07 at 10:00 PM Reply With Quote
Humbug, thanks for that - guess I knew the answer but you live in hope! It's probably going to be used for track days etc so SVA at this stage seems a lot of hassle for not much return. Cheers, Pewe
