Author: Subject: Brake line clip distance
FlansS14
posted on 2/3/07 at 09:26 AM Reply With Quote
is it 15cm or 30cm the line has to be secured.
Why didn't i just make it simple!
shortie
posted on 2/3/07 at 09:28 AM Reply With Quote
30cm
Rich.
posted on 2/3/07 at 09:30 AM Reply With Quote
30cm, but I used 25cm just to make sure
FlansS14
posted on 2/3/07 at 11:53 AM Reply With Quote
Thanks Guys, i thougt it was 15cm for some reason.. that makes life easier now
flak monkey
posted on 2/3/07 at 12:26 PM Reply With Quote
Theres not actually a max specified in the SVA manual for brake or fuel lines, only for wiring.
In the case of fuel and brake lines the requirement is that they are 'securely' fastened. For wiring its 300mm max.
You are of course recommended to clip everything at intervals of less than 300mm just to be on the safe side!
Sera
http://www.motosera.com
