scoey m
posted on 2/3/07 at 07:57 PM |
PIPE FROM RES
Hi All
Anybody using cohline 2322 pipe supplied by think auto for res to master cylinders wondering if any body as data sheet saying the suitability of this
pipe for brake fluid use to keep sva man happy
Martin
chockymonster
posted on 2/3/07 at 11:02 PM |
I do have the spec sheet, I'll see if I can get a copy to you.
posted on 3/3/07 at 08:06 AM |
Didn't need the spec sheet as the SVA tester should be able to tell from the markings on the hose. The correct hose is normally covered in a
blue fabric? if that is any help
scoey m
posted on 3/3/07 at 10:29 AM |
cheers for replies guys
Just dont fancy risking little things like this to fail on i want to be prepared and have correct info to be on the safe side
Paul u2u sent
Martin
