Author: Subject: Alloy Dash
defender
posted on 8/3/07 at 11:49 PM Reply With Quote
Alloy Dash
would an alloy dash with an lcd screen pass the sva?
Confused but excited.
posted on 9/3/07 at 12:02 AM Reply With Quote
Ali dash is OK if it meets the requirements. Wouldn't recommend watching TV whilst driving tho'.
fesycresy
posted on 9/3/07 at 08:17 AM Reply With Quote
Are you putting a finish on the 'alloy' ?
You don't want to blinded by glare at an important moment
RazMan
posted on 9/3/07 at 09:49 AM Reply With Quote
Agreed, the glare from any shiny dash (including painted) can be very distracting, especially in an open car.
Ref the lcd screen, it will still need to conform to radius regs but otherwise it should pass ok.
Raz
wicket
posted on 9/3/07 at 12:42 PM Reply With Quote
Don't forget the bottom edge needs to have a 19mm rad.
Bob C
posted on 9/3/07 at 12:44 PM Reply With Quote
I made an ally dash with 40mm diam tube bottom edge, covered it in vinyl. Easy enough if you have TIG technology...
Chenti
posted on 9/3/07 at 01:50 PM Reply With Quote
Wow...that Dash must be really heavy....
You need a Carbon one mate....
Bob C
posted on 9/3/07 at 03:46 PM Reply With Quote
heavy? the Al sheet is 1mm thick & the tube about 1.5mm wall - the thing weighs nothing.....
bob
(tube looks thick walled but that's just where it was 'dressed' (hammered) to get a bit of a radius at the end.
chockymonster
posted on 9/3/07 at 04:04 PM Reply With Quote
What LCD screen are you using?
Have you checked to see if you can actually see it in daylight?
Unless it's a transflective screen I doubt you'll be able to and I doubt the old bill will accept "I couldn't see the speedo cos it's too sunny" as a valid excuse.
