goodguydrew
| posted on 9/3/07 at 01:31 AM |
Escort V5 please?
Hi all,
I am building an "original" book based car, with an S1 period look like this picture below. I don't have anything against Q plates,
but I would really like to be able to transfer a period plate onto the car when complete, just to make it look right. So, does anyone have an Escort
V5 available?
[Edited on 9/3/07 by goodguydrew]
goodguydrew
| posted on 9/3/07 at 01:34 AM |
Picture...
Humbug
| posted on 9/3/07 at 08:23 AM |
Surely you don't need an Escort V5? If you qualify for an age-related plate, you can then transfer any reg? In any case, the oldest Escort reg
would have a suffix letter, so would not be the same period as the Series 1 (only produced to 1960).
| posted on 9/3/07 at 08:42 AM |
you won't be able to transfer any reg. period.
now if you can show that you have used 2 major components from the donor, then if you are lucky, you will get an age related plate - i.e. a
regisration that is the same age as that of your donor vehicle.
I am not sure but I don't think you can then replace your age related plate with a different or older plate.
James
| posted on 9/3/07 at 01:19 PM |
Pretty sure you can, like any plate can be changed for an older one.
- Muhammad Ali
iank
| posted on 9/3/07 at 01:33 PM |
I've also read that age related plates issued to kits can't be transferred.
http://www.dvla.gov.uk/media/pdf/consultations/summ_190404.pdf
Which states that "• That all kit converted vehicles built using a new or modified chassis/bodyshell be allocated non- transferable VRMs and
that cherished transfers be prohibited in the same way as ‘Q’ registered vehicles."
Anonymous
SeaBass
| posted on 9/3/07 at 01:34 PM |
Yep if you get an age related you can put on a personalised or older plate.
If you get a Q you cannot change the reg at all.
The document above refers to a 'recommendation' has this actually been executed yet??
[Edited on 9/3/07 by SeaBass]
Stu16v
| posted on 9/3/07 at 07:29 PM |
Correct, You cannot transfer the kit car age-related plate onto another car. But you can transfer a plate of the same, or older age onto the kitcar...
