Author: Subject: ahh me brain!!
Mr Whippy
posted on 12/3/07 at 10:21 AM Reply With Quote
ahh me brain!!
Ok don’t worry this has nothing to do with a 7, thankfully…
Just a legal question about registration stuff. If someone were to say take a production car body and plonk it on top of a new chassis which has a different engine and running gear from the original car but and I stress the BUT bit, the cars body is untouched otherwise, would it be able to keep its original registration. An example maybe a LandRover with a body swap where the body would retain the registration of the chassis, though this is really the other way round as it is the chassis which is new. Tricky I know. It all seems to depend on what constitutes a chassis and what would be considered a suspension subframe.
any ideas???
posted on 12/3/07 at 10:33 AM Reply With Quote
^^^^ in other words you replace the old chassis by a new one?
I beleive you retain the original registration as long as the chassis is to the same spec.
i.e. if you have a leaf sprung landie and slap it ontop of a coil sprung one, that is a big no-no (and may need SVA?). Your LR would loose tax exempt status if the orginal vehicle was pre '73 and you use a coil chassis.
owelly
posted on 12/3/07 at 10:41 AM Reply With Quote
Is it not back to the points thing??
http://www.ppcmag.co.uk
Mr Whippy
posted on 12/3/07 at 10:51 AM Reply With Quote
oops forget the landy's, bad example...think 'car' on new chassis/subframes jacked up monster truck/dune buggy type 'thing', yikes!
wish I had a picture, but the you'd laugh at me, again
[Edited on 12/3/07 by Mr Whippy]
flak monkey
posted on 12/3/07 at 11:02 AM Reply With Quote
If you build a new chassis or modify an old one and stick an old body on it, it will need an SVA. The volkwagen beach buggies etc that use modded chassis, all require an SVA.
The only times you can use a new chassis and not need an SVA is in something like a restoration on an MGB where a complete new shell is available from Heratige motors, and is to the same spec as the original.
Sera
http://www.motosera.com
Mr Whippy
posted on 12/3/07 at 11:05 AM Reply With Quote
hmm I suspect your right, ta
RazMan
posted on 12/3/07 at 11:31 AM Reply With Quote
When you think about it the chassis is the structural part and the body is purely cosmetic (loosely speaking) so the new chassis will have to go through SVA and DVLA.
Raz
Mr Whippy
posted on 12/3/07 at 11:38 AM Reply With Quote
Bit of a gray area this one, as the chassis is an additional one as the 'car' body shell is a chassis in it's own right. Not a problem though as the SVA is really not that bad especially when the cars shell and interior are already SVA compliant. Just needs bloody big plastic cycle wings!
iank
posted on 12/3/07 at 11:58 AM Reply With Quote
Interesting question (the original one). If one end's suspension is all bolted into a frame which is in turn bolted onto a chassis I'd expect it to be counted as a subframe and be SVA free. Just like a mini and countless modern FWD cars, the chassis is counted as the monocoque.
If suspension from both ends is attached to a single frame or the frame is then welded in I'd say it was a chassis.
The car body which is the 'chassis' in a monocoque couldn't be modified 'significantly' to accept the frames. Chopping out the floor wouldn't be acceptable for example.
There seems to be a slightly off-grey area with chassis modifications since you are allowed to make minor alterations (otherwise fitting an aftermarket sunroof, or indeed welding in new non OEM sills, would require SVA!)
Anonymous
Mr Whippy
posted on 12/3/07 at 12:16 PM Reply With Quote
well your kind of following my logic, the car in question does as standard have two seperate suspension subframes but as these are no use for the intended suspension they would be replaced by new subframe/s along the lines of a space frame chassis with double wishbones and uprights.
The engine and gearbox is also to be replaced as its frd as standard and the end product is to be 4wd.
Confused but excited.
posted on 12/3/07 at 02:48 PM Reply With Quote
[Quote] Just needs bloody big plastic cycle wings! [Quote]
Thinking of doing the Paris/Dakar are we?
