Author: Subject: 2CV headlights
jambojeef
posted on 16/3/07 at 01:37 PM Reply With Quote
2CV headlights
Will they fail SVA?
Im pretty sure they dip down but not to the left. Is this going to be a problem?
There are obvious clips at the top of the headlamp bowls which will fail on sharp edges but what about the beam?
Geoff
Agriv8
posted on 16/3/07 at 01:38 PM Reply With Quote
Dax's pass with them so there must be a way
regards
agriv8
westf27
posted on 16/3/07 at 01:41 PM Reply With Quote
mine passed ok at southampton if that helps
555
iiyama
Dax units arnt 2CV, however they did use to be. Not sure how long ago they changed.
If its broke, fix it. If it aint broke, take it apart and find out how it works!
Agriv8
posted on 16/3/07 at 02:04 PM Reply With Quote
Apologies stand corrected.
regards
Agriv8
Mike S
posted on 16/3/07 at 02:05 PM Reply With Quote
This whole headlight thing seems to be another of those gray areas.
I have purchased some dip beam headlights from Westfield which are the small projector type used in the XTR2. Westfield assure me that they are ok for SVA.
Powered them up recently to have a look at the beam pattern, and for the life of me they look like they just have a flat cut off.
I have looked at the SVA manual and it has a note on the beam pattern diagram that states "An alternative headlight dip beam pattern (not being one of the examples given in this section) is acceptable provided all of the beam upper edge, including any "peak" is contained within the appropriate tolerance band.
So, it looks to me like they are saying you can have a kick-up, but if you do, it must be to the left side and the position of the break from horizontal to the kick-up must be within the parameters.
If you don't have a kick-up then there is no break point.
They also say in the notes that some headlights will not have an image kick-up or break point.
As far as I can see, flat dip beam patterns are ok provided they stay under the cut off line.
Mike
There are more horses' asses in this world than there are horses
iiyama
posted on 16/3/07 at 02:12 PM Reply With Quote
regards
Agriv8
Apologies from me also, Reading my post again it came across a little agressive! Didnt mean it to be!
jambojeef
posted on 16/3/07 at 03:32 PM Reply With Quote
You kind souls!
I didnt read any aggresion into anyone's replies but thankyou very much.
Guess I'll just see what happens at SVA then?
They arent ideal since mine have external clips with sharpish edges which I think will need covers but its about 110 quid for new headlights from premier and places so maybe its worth a try.....
thanks
Guinness
posted on 16/3/07 at 04:00 PM Reply With Quote
You can always borrow a set for a (re-test) day!
It's only two bolts to remove them! & some of those smoke pipe things.
Mike
You about this weekend Jeff?
Blackbird Rush
posted on 16/3/07 at 04:23 PM Reply With Quote
The Dax Supplied rectangular 2cv/dyanne headlamps should be fine for SVA, i have these for my dax, dont have any sharp edges or clips??.
Due to the rarity of the citroen lights dax offer different rectangular headlamps now (off a van or similar commercial vehicle) with their own made back cases.....
HTH.
jonbeedle
posted on 16/3/07 at 04:45 PM Reply With Quote
I have 2CV round headlights. Mine passed SVA.
"Everyone is entitled to an opinion however stupid!"
jambojeef
posted on 16/3/07 at 05:09 PM Reply With Quote
Cheers Jon!
And thanks for the offer Mike - but I couldnt do it to the poor Indy!
Im about this weekend fo sho - you gonna drop by?
Im bonnetting - if you catch my drift?!
graememk
posted on 16/3/07 at 05:17 PM Reply With Quote
JCB headlights
graememkoct15
graememkoct15
Guinness
posted on 16/3/07 at 05:21 PM Reply With Quote
Bonnetting
Nice!
Thought I might pop over later on tomorrow afternoon?
Mike
Macbeast
posted on 16/3/07 at 05:36 PM Reply With Quote
I guess 2CVs registered in this country must pass MOT so lights should be ok for SVA. Or is that too simplistic ?
blue2cv
posted on 16/3/07 at 06:38 PM Reply With Quote
My department at last, 2cv h/lamps will have correct dip pattern if bulb is installed correctly (i've lost count of the amount we put right when servicing), on some lamps there is a black plastic slide which enables a switch between r/hand and l/hand dip
jambojeef
posted on 16/3/07 at 08:15 PM Reply With Quote
Woah an expert! Thanks for the 2CV info!
Mike - be good to see you, give us a call for directions since we've moved dont forget!
Thanks for the replies everybody - I shall just need some clever ideas for something to cover the catches on the top of the bowls.......methink the vacuum forming machine may be dusted off!
Geoff
