Author: Subject: im building a Lamborghini Countach kit
ukbaggio
posted on 18/3/07 at 08:30 PM Reply With Quote
hiya all im new to this site...
can anyone help please im building a Lamborghini Countach kit and using a jag V12 in it.... when done how do i NOT get a Q plate on it thanks baggio
ukbaggio
posted on 18/3/07 at 08:44 PM Reply With Quote
it was part made but i will be using reconditioned parts all the way thanks baggio
nitram38
posted on 18/3/07 at 08:46 PM Reply With Quote
As long as you have 3 major parts from a donor (3 points) and a manufacturers chassis (5 points, total 8) , you can get an age related plate or if you have one reconditioned item (usually engine) and everything else is brand new (you will need to provide proof), you can get a brand new reg.
What kit is it?
I have built a Mirage.
[Edited on 18/3/2007 by nitram38]
ukbaggio
posted on 18/3/07 at 08:50 PM Reply With Quote
mines a GB kit but can use Mirage bits looking for a gearbox for it at the mo thanks baggio
nitram38
posted on 18/3/07 at 08:54 PM Reply With Quote
GB kit, that must be 25 years old!
The main problem with their kit is that the v12 is partially into the rear fire wall and handling was poor.
I would go the V8 route or use a V6 audi turbo and transaxle.
GB went awol for a very good reason!
ukbaggio
posted on 18/3/07 at 08:57 PM Reply With Quote
the cars got a jag v12 lump in it and using a Renault 30 gearbox was running ok but gearbox is only 4 speed
ukbaggio
posted on 18/3/07 at 09:10 PM Reply With Quote
well i need 2 replace the the v12 so what do u think i should put in her
thanks baggio
nitram38
posted on 18/3/07 at 09:16 PM Reply With Quote
It all depends on your budget.
Rover V8 plus Renault 30 transaxle (if you can find one!)
BMW V12 (shorter than jag) and audi transaxle. Both will need adapter plates/bellhousing and flywheel clutch conversions.
Audi v6 turbo and transaxle.
Whatever you go for it will be expensive.
Look at parralleldesigns website.
ukbaggio
posted on 18/3/07 at 09:20 PM Reply With Quote
thanks been to parralleldesigns in mitcham and found out that its an old m8 runs it thanks baggio
nitram38
posted on 18/3/07 at 09:27 PM Reply With Quote
Naz will probably talk you out of the GB then and tell you to buy a Diablo!
We all progressed from countach kits because they are generally a nightmare to build and parts are difficult to get.
You will probably have trouble with things like windscreen that fits and curved or flat door glass.
Naz has sorted the diablo so you can buy everypart and it will look right too!
Mr Whippy
posted on 19/3/07 at 12:32 AM Reply With Quote
you have U2U, I have the answer to all your problems
[Edited on 19/3/07 by Mr Whippy]
