Author: Subject: Battery Master Switch
edspurrier
posted on 2/4/07 at 01:31 AM Reply With Quote
Pondering when to fit my battery master switch so we can race the Avon eventually.
Has anyone had an FIA switch fitted for the SVA? I was planning to put it on the right side of the body near the bottom of the windscreen, so I'm a bit worried about the exterior projection issue.
RazMan
posted on 2/4/07 at 06:52 AM Reply With Quote
Probably best to install it after SVA
Raz
iank
posted on 2/4/07 at 07:26 AM Reply With Quote
nitram38 came up with an interesting solution. He encased the key (and immobiliser transponder) in resin.
http://www.locostbuilders.co.uk/viewthread.php?tid=62565
Anonymous
nitram38
posted on 2/4/07 at 07:30 AM Reply With Quote
I put my key in a round deodorant top and encased it in clear resin. Not only does it get around the projection problem, it contains my immobiliser transponder key.
This means that someone with an ordinary fia key cannot nick the car!!!
posted on 2/4/07 at 07:56 AM Reply With Quote
Very clever! What's the 1p for?
nitram38
posted on 2/4/07 at 07:59 AM Reply With Quote
Most people do not realise that a 1p is mostly steel and therefore magnetic.
I just use it to attach the key onto a magnet when not in use!
posted on 2/4/07 at 08:04 AM Reply With Quote
Good thinking!
edspurrier
posted on 4/4/07 at 05:15 AM Reply With Quote
Now that IS cunning.
I might just make the key removable - there's a little rubber cover for the socket which should be SVA happy.
