Author: Subject: Fuel Line clips
Dave Bailey
posted on 12/4/07 at 08:18 PM Reply With Quote
Fuel Line clips
Anyone used these for mounting two fuel lines and gone through SVA. If so what distance apart? I am using nylon lines....
thanks
Dave Bailey
Dave Bailey
posted on 13/4/07 at 11:33 AM Reply With Quote
Okay different question..... Anyone think there will be a problem using them?
Dave B
posted on 13/4/07 at 01:54 PM Reply With Quote
from what I know, fuel lines need to be marked as such. dunno about those clips but as long as the fuel pipes are secure it should be fine - I would question those clips as the lines "press in" so in theory takes less effort to pull out than say a riveted p-clip (at a guess).
why make life difficult and not use p-clips? known to be SVA friendly.
remember if they fail, it will be a right pig to get at them all to replace them so I wouldn't chance it.
(or write letter to SVA?)
posted on 13/4/07 at 07:32 PM Reply With Quote
I used similar clips on mine with no problems although I used 1x8mm pipe and 1X 3/16" brake pipe. Put them a least every 300mm although I think that is the requirement for wiring. Are you using injection? If so where did you get the fuel pipe?
Dave Bailey
posted on 14/4/07 at 10:01 AM Reply With Quote
I am usin nylon that I bought from lolocost. No markings on it but they said they would send me a c of C but they didn't. I think others have used it.
I am fiting 2 litre zetec with throttle bodies. Flow and return is 8mm od 6mm id. Hope this will be o.k.!
Dave B
