Paradoxia0
posted on 30/5/07 at 10:27 PM |
Aeroscreen hight and mirrors...
Hi Guys and Gals,
Anyone one know of the rules on height of aeroscreens?
I fitted the Luego supplied one to my Viento last night and just sat in it this evening and in a normal seated position I am looking through the top
inch or so of screen when looking straight ahead (admitedly the car is on axle stands at the moment so not 100% certain what it will be like a ground
level).
Also, exterior mirrors.
I have been looking at fitting my exterior mirrors this evening and got thinking about the swivel rule...
The SVA book states:
"In the case of exterior mirrors mouted ont nearside and offside of the vehicle, that they:
are capable of rotating inwards towards the vehicle when a force of 10kg is applied horizontally at the extreme outer edge from both the front and the
rear"
and
"have an axis of rotation to be within 50mm of the vehicle surface to which they are mounted"
It then follows to say that the criteria does not apply to a mirror "which does not protrude beyond the extreme outer edge of the
vehicle".
Does that mean that if the mirror is inside the line of the rear arches it doesn't need to swivel inwards? My concern is the mirrors I have do
swivel but not what I would call inwards....
Mark
There is no replacement for displacement...
DavidM
posted on 30/5/07 at 10:31 PM |
Generally on a seven they do not need to swivel as they are within the outline of the bodywork. That is unless you are going to fit some of those they
use when towing caravans.
graememk
posted on 30/5/07 at 10:42 PM |
pop over and have a look at mine if you like
mine passed sva with aero screen
posted on 31/5/07 at 08:08 AM |
yes, here it is.
The maerasument technique is non trivial.
screen poistiion
Paradoxia0
posted on 31/5/07 at 10:39 AM |
I think I need a coffee or two before I try to measure/work that out!!!
Mark
Rubin
posted on 31/5/07 at 12:18 PM |
leave it off until after the test is what i have been recommended. i.e plain scuttle
