Author: Subject: fluke dash
iceman26
posted on 31/5/07 at 10:22 PM Reply With Quote
fluke dash
im looking at getting fluke dash are they ok for sva with the bottom edge
and if not how have you got arond the bottom edge
or if any one can recomed dash to me it must
be flat and run straight along bottom edge
thanks
StevieB
posted on 1/6/07 at 07:21 AM Reply With Quote
From what i've seen of the Fluke dash, it should be just fine for SVA (thinking of using one myself).
The only problem I can see is the fact that it doesn't turn down at the outer sides where your scuttle meets the side panels, so you'd have to come up with something to cover that.
Personally, I'm going to make a plywood/vinyl temp dash for SVA and will eventually get around to putting the Fluke dash in afterwards - better to turn up with a car that will definately not fail for the sake of silly things like dash radius' etc. and upgrading things later.
