Author: Subject: Front indicators on my MK indy ? are 25mm stalks ok for SVA?
RichyMkIndy
posted on 20/8/03 at 05:20 PM Reply With Quote
ive bought some 35mm indicators on stalks for my mk are these SVA friendly ? just wanted to check ?
Thanks Rich
Wadders
posted on 20/8/03 at 06:57 PM Reply With Quote
The indicators on my car are identical to the indicators on MarkH's car. His failed at Nottingham, cause they didn't stick out enough, mine went through at Beverley with no problem.
It's a lottery mate.
posted on 20/8/03 at 06:59 PM Reply With Quote
You mean 35 mm long? I think there is no regs on size, so long as they work. They probably fall in the exempt area behind the wheel so i think that they will be OK. Also they would probably snap if you wacked them...
Second opinion anyone?
Ooops, i stand corrected! Im off to beverley anyway, thats my excuse!
[Edited on 20/8/03 by JoelP]
Simon
posted on 21/8/03 at 10:01 AM Reply With Quote
So long as they are e-marked and mounted in accordance with lighting regs, and mountings are within radii regs, I can't see how they can be failed.
Simon
stephen_gusterson
posted on 21/8/03 at 11:06 AM Reply With Quote
if the indicators are more than 400mm inboard of the outside edge of the car they WILL fail.
atb
steve
zetec
posted on 21/8/03 at 05:00 PM Reply With Quote
And remember to check if the rear is wider than the front. They must be within 400mm of the most outer edge of the car, not counting mirrors. My Indy appears about 20mm wider at the back than the front.
Mark H
posted on 25/8/03 at 12:17 PM Reply With Quote
Zetec and Steve G are exactly right with regards distance from outside of vehicle. Mine were a borderline fail. I stuck an extra inch extender on each one (I've got them somewhere if anyone fails and wants these).
But as you'll no doubt fail on more than these (!) i would take the risk. IF you fail on them then sort out some extenders.
Mark
Mark Harrison and
Q986 KCP back from the dead...
