Author: Subject: Edges or centres of headlamps
Mark Allanson
posted on 23/8/03 at 05:48 PM Reply With Quote
Just want to double check headlamp positioning. as I read it, the base of the headlamp must be 500mm off the ground and the outer edge must be 400mm from the most extreem outer part of the car.
Just want confirmation before I make the last weld! The guide is a bit vague about edges and centres of headlamps
Thanks,
Mark
stephen_gusterson
posted on 23/8/03 at 06:25 PM Reply With Quote
according to my 2000 manual thats right. the dimensions are from floor or outer edge of car to the extreme edge of the lit glass area.
atb
steve
Mark Allanson
posted on 23/8/03 at 06:33 PM Reply With Quote
Thanks Steve, let the sparks fly!
GO
posted on 27/8/03 at 01:53 PM Reply With Quote
Dumb question but just want to be certain... the same would apply then for all lights? brake lights, indicators etc - as long as any part of the lens falls within the measurement from the outside of the car its ok?
