dunkan
posted on 25/8/03 at 07:56 PM |
fuel cut-off?
Is it a legal requirement (SVA) to have have a fuel cut-off switch fitted with carbs/electric fuel pump?
stephen_gusterson
posted on 25/8/03 at 10:28 PM |
I cant recall seeing it.
But consider your own safety. A cut off impact switch can be easily wired to the coil of the fuel pump relay.
Having a bad accident with a ruptured fuel line and 4 litres or so a minute pumping on the floor isnt gonna get a big crowd of people to pull you from
the car.....!
atb
steve
[Edited on 25/8/03 by stephen_gusterson]
Jon Bradbury
posted on 26/8/03 at 07:23 PM |
Good point Steve.
Dunkan,
You can get a fuel cut off switch from any Sierra post '91. It is located in the boot in the spare wheel well. Two pozidrive screws later and
it's yours. Take the mounting bracket too. A scrappy will probably only charge a fiver for it (oh, and cut the connector off the loom so you can
wire it into your car.)
JonB
Mark Allanson
posted on 26/8/03 at 07:57 PM |
"You can get a fuel cut off switch from any Sierra post '91."
Any injection Sierra will have one, thats back to '85
suparuss
posted on 26/8/03 at 10:28 PM |
i heard/read somewhere that the best place to wire the cut off is using the oil pressure switch. cant remember where, or why, but i remember it making
sense at the time.
stephen_gusterson
posted on 26/8/03 at 11:08 PM |
its not that simple
no oil pressure at start up, so the fuel pump wont prime.
My efi system - granada based - runs the pump for a couple secs at key on, then stops. It then only starts once it senses engine run.
If you use the oil switch, the engine of a crashed car will stall, and the switch will turn of the pump. A metro turbo does this. However, the pump
wont run at engine start time unless you have a 'primer timer'.
an impact switch is much easier! Just wire it to the fuel pump relay coil. I wouldnt do it direct to the pump - its fused at 20A so a bit current
hungry I guess
atb
steve
[Edited on 26/8/03 by stephen_gusterson]
