Alan B
posted on 27/8/03 at 05:18 PM |
Headlight height
Ok, I've done a search and skimmed a PDF copy of SVA regs but can't find anything about headlight height.
Anyone know the minimum height of headlight centres to the ground?
stephen_gusterson
posted on 27/8/03 at 05:27 PM |
someone doesnt bother to read posts of a few days ago do they alan!
the lit glass area must be no more than 400mm from the vehicle edge, and the lowest point of the glass must not be below 500mm
atb
steve
[Edited on 27/8/03 by stephen_gusterson]
Alan B
posted on 27/8/03 at 05:33 PM |
Ah, but Steve, I wasn't interested then...
Thanks for the info....If I can easily position my lights to meet SVA and US requirements then it would stupid not to.....
Although my list of "stupid things I've done" is scarily long..........![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
tadltd
posted on 10/9/03 at 08:57 AM |
Guys,
My understanding of the headlamp height rule is that the 'beam cut-off' point should be 500mm from the ground - this doesn't
necessarily mean the lower edge of the lamp (have a look at 5 1/4 inch lenses and you will see a clear definition of where the beam cut off is).
Proof of this can be seen on the McLaren F1 road car, where the bottom of the lamps are sunk into the lamp housing to the point where the beam cut-off
is.
Hope this helps. Sorry if it hinders!
Steve. ![](/images//smilies/smile.gif)
stephen_gusterson
posted on 10/9/03 at 10:17 AM |
hi
that may all be true
BUT
it specifically states in writing in the SVA manual that the glass area must be no more than 400mm from the side and no less than 500mm from the
ground.
atb
steve
tadltd
posted on 10/9/03 at 10:52 AM |
I have a 2002 version SVA manual, so perhaps it has been reviewed?
Although, in saying that - the McLaren F1 was an early 90's car...
Steve.
