adithorp
posted on 17/7/07 at 03:41 PM |
Fog lamp
Is there any requirement for a symbol on the fog light tell tale? Doesn't look like it reading the manual but I thought I'd check.
Also should it be wired to work only when side and headlights are on as most cars are?
Adrian
posted on 17/7/07 at 03:43 PM |
No and Yes
flak monkey
posted on 17/7/07 at 03:55 PM |
No requirement for a symbol on tell tale. i just used a toggle with an LED in the end of the lever.
Also doesnt matter if it comes on when the headlights are on or not. Mines totally independent, probably sensible to wire it up so it will only work
when the headlights are on though.
Sera
http://www.motosera.com
posted on 17/7/07 at 04:54 PM |
No symbol requirement.
When I had SVA the regulation was that it should only operate with dip beam but that seems to have changed now and a lot of production cars have the
hazard so it can come on with sidelights,dip and main beam. It should not work with no lights on at all. Best check with the station where you are
going for SVA.
