Author: Subject: securing Brake - Fuel - Elec pipe work...
johnemms
posted on 7/8/07 at 12:00 PM Reply With Quote
Hi ya...
I fancy making some mild steel strips - tack weld to chasis - bit of rubber tube - and bend them to secure various pipe work in the good old fasioned way...
Now.. is this ok with sva? and if so is there a recomended minimum spacing of the clips?
Lastly.. can i use a plastic - poly aprox 1" tube secured in the tunnel as a conduit so i can simply pass wiring from front to back of car?
Thanx in advance for any advice
jon
designer
posted on 7/8/07 at 02:18 PM Reply With Quote
Just use P clips 10in maximum apart
Macbeast
posted on 7/8/07 at 04:31 PM Reply With Quote
Was looking at this today. New book says clips max 100mm apart in tunnel. This seems a bit close to me ?
Edit:
Flakmonkey's build diary says about 200 mm apart.
[Edited on 7/8/07 by Macbeast]
