locoboy
| posted on 8/8/07 at 08:17 AM |
SVA eye over please
Its my turn finally to ask you knowledgable lot to cast your beady eye over my car and let me know of any potential issues,
SVA 8.00 tomorrow ................Parrrrrp!
  sva1
[img]http:/www.locostbuilders.co.uk/upload/4sva2.JPG[/img]
  sva3
  sva4
  sva5
  sva6
  sva7
Locoboy
| posted on 8/8/07 at 08:24 AM |
I'm not sure what they'll think of the edging used on the arch supports. Is edging material allowed to have a non-radiused edge?
Have you used self-amalgamating / vinyl tape on the front suspension to cover up the nasties? At my first SVA it was deemed non-permanent (might be an
issue). Might be worth taking some split radiator hose and tie-wraps just incase....
Is the tunnel top definitely radiused enough?
GOOD LUCK!
| posted on 8/8/07 at 08:26 AM |
PS Make sure you pick up the rivet bits under the silencer can. If you run them over they can cause punctures. Having to mend that on the morning of
SVA would not be good!!!
SeaBass
| posted on 8/8/07 at 08:33 AM |
The edges of the exhaust collectors look like they are exposed?? Why the big Exhaust shield?
locoboy
| posted on 8/8/07 at 08:42 AM |
Top bone has a rubber pad on it wrapped in salf amalgamating tape
The tunnel was hand bent so i would think its radiused enough...........i hope.
yes puncture on SVA morning is not a good start, i will get the broom out!
Locoboy
locoboy
| posted on 8/8/07 at 08:45 AM |
Edges of exhaust collectors are exposed,
Its an MK exhaust up the the collector, how have other MKers got around this problem?
Big exhaust shield to cover the clamps and the Lambda boss on the scilencer end of the collector.
I just ectended it by 6 inches, it was big initially as it has 2 cats under there!
Locoboy
Agriv8
| posted on 8/8/07 at 08:53 AM |
Rear reflectors in your tool box so you can fit the where the SVA man is happy with ?
regards
Agriv8
locoboy
| posted on 8/8/07 at 08:56 AM |
Shit!
Agriv8, completely forgot about them, Phew
Locoboy
Agriv8
| posted on 8/8/07 at 09:19 AM |
Cant see your Hand brake on / low level warning light this usually needs to have the correcy (!) symbol on.
Right here is a really anal one for you and trust me people have been failed on it.
on your Dash the dommed allen cap heads
I would put a blob of silcone in them, the allen key hole does not meet the radius rule and can be classed as a sharp edge people have been failed for
it.
( ps it it tends to fall out just after SVA )
regards
Agriv8
locoboy
| posted on 8/8/07 at 09:24 AM |
The handbrake light is the lower one on the centre of the dash obscured by the wheel in the photo,
Anal ok!
they are self tappers and are already full of silicone
[Edited on 8/8/07 by locoboy]
Locoboy
| posted on 8/8/07 at 09:33 AM |
masking tape on the brake hose, indicator extension, wish bone, track rod - deemed not permanent
I used split convoluted hose and cable tied it on.
right angle wing stay - not good.
trim on heat shield - not deeemd as durable
hand brake surround - radius surely?
fog lamp height?
locoboy
| posted on 8/8/07 at 10:23 AM |
fog lamp height?
Its self amalgamating tape, some have been ok some have not with this stuff, deemed permanent at some centres as you need a 'tool' ie a
knife to get it off. Suck it and see i think on that one.
split convoluted hose seems less permanent than the amalgamating tape IMO, i tried to get some of it off and its bloody tough!
wing stay is a concern, micht put some split rubber hose over it and see how it goes.
Handbrake surround is fine, its got a + 5mm rad on the outside and tadpole trim on in the inside
fog light can be up to 1000mm high so thats within scope too.
good points though fellas, keep em comming
Edited to say,
I have just spoken to MK refernce the welds on the collector and they said at Notts SVA centre they have never had a problem and have never had to
cover them up. Fingers crossed that Shrewsbury see sense too
Locoboy
| posted on 8/8/07 at 10:53 AM |
To be honest they're taking the wee if they say that a glowing red collector is dangerous because it has moderately sharp welds on it!!!!
Avoneer
| posted on 8/8/07 at 11:08 AM |
Nut covers on the top and bottom of lower ball joint nuts to make sure.
Pat...
locoboy
| posted on 8/8/07 at 11:19 AM |
Ok,
Cheers Pat,
Congrats on your pass btw
Locoboy
Dave J
| posted on 8/8/07 at 12:42 PM |
The radius on the bend of your front flexible brake hoses looks a little tight. If it gets any tighter when on full lock, the SVA chap may not like it
as it could over a period of time cause the hose to collapse at that point. I know of builder who was picked up on just that point.
Dave
RichardK
| posted on 8/8/07 at 05:41 PM |
What is the 2nd method of securing the front upright mushroom inserts, as I understand the pinch isn't enough on it's own. Maybe a small
grub screw would suffice.
Rich
Gallery updated 11/01/2011
matt_claydon
| posted on 8/8/07 at 05:55 PM |
Rich
Whilst I heard someone having trouble with that, I don't think it's the norm. Afterall, MacPherson strut production cars don't
usually have an extra means.
RichardK
| posted on 8/8/07 at 08:19 PM |
Thought they have a tab welded to the strut that goes through the pinch section.
I believed it was this is like this so even if the pinch bolt comes loose the strut can't come out, only if the bolt falls out totally can the
strut come out, where as with the mushroom if that comes loose then a failure can occur.
Hopefully it isn't a problem as I haven't done anything wrt to it either!
Rich
[Edited on 8/8/07 by RichardK]
