Jimbob
posted on 4/9/07 at 04:04 PM |
Failed again
Up on the lambda again!
Thats the only thing it fails on, too lean but im running as rich as i can running out of ideas!?
James
Dillinger1977
posted on 4/9/07 at 04:07 PM |
mine was too lean on the lambda, discovered I had a tiny leak around the exhaust headers.
copious amounts of fireweld, and it passed next time. (borderline too rich, as i'd actually been running it too rich to overcompensate for the
false lamba reading)
also anything like an AIS system will give a false lambda by dumping fresh air into the exhaust to burn off hydrocarbons.
-Rog
Jimbob
posted on 4/9/07 at 04:11 PM |
So i can take the AIS off? just remove valves and blank off?
Im gonna go check my headers now cheers!
James
Dillinger1977
posted on 4/9/07 at 05:13 PM |
as far as I know, yep. take it off and blank the holes.
or in my case, I left it on and blocked the big sucky pipe that draws air from the airbox, and I also nipped the vacuum pipe from the 1st cylinder so
the valves wouldnt work.
(r1 specific)
regarding the headers, I started it from cold and put my hands near them. there was a definate 'warm spot' inbetween 2+3 which gave it
away a bit.
kept applying a bit of fireweld and trying again until it went away. looks a bloody mess now but no more SVA!
all of this is my experiences and I could be well off the mark. Someone more informed might be along soon to give some better answers.
-Rog
Avoneer
posted on 4/9/07 at 06:35 PM |
Talk to Mac#1 about there SVA service - they should be able to sort it but at Nottingham.
Pat...
Jimbob
posted on 4/9/07 at 07:39 PM |
Whipped the AIS off and blanked it off with some ally plates and found a tiny blow from the back of one of the headers so might be on track now
Will whip it round to a local garage and see
All else fails MAC1 to the rescue!
cheers guys
James
Avoneer
posted on 4/9/07 at 09:17 PM |
Does cost a premium mind, but one well worth paying for a very successful pass rate.
Pat...
