Author: Subject: Where and how
locoboy
posted on 6/9/07 at 01:06 PM Reply With Quote
Where and how
Im looking for ideas of where and how to mount the front number plate on my car.
what and where have you done yours. - photos would be good!
Ideally a sticky one would be best but it takes time to get one of them!
Locoboy
andyharding
posted on 6/9/07 at 01:20 PM Reply With Quote
Easy - I don't have one. Kept bashing it so took it off.
scoobyis2cool
posted on 6/9/07 at 01:21 PM Reply With Quote
I bent a couple of bits of aluminium, bolted them to the bottom of the nosecone and then through the number plate, like this:
Front View
Front View
The only other way I can think of off the top of my head is a sticker on the top of the nosecone. I have a feeling it's not actually legal but I'd say the chances of getting done for it are slim.
Pete
posted on 6/9/07 at 01:51 PM Reply With Quote
I have a stivky on blank plate you can have - it has been driven over by a Land Rover so not pristine but as you are selling it doesn't matter
also the letters OWU 264 V or something like that - may be of use if you use same letters/numbers, (this was the reg of the donor that one of the previous ownners though would get transeferred).
UncleFista
posted on 6/9/07 at 02:32 PM Reply With Quote
Hehe, me neither, never had one in 3 years on the road
Tony Bond / UncleFista
graememk
posted on 6/9/07 at 02:53 PM Reply With Quote
i have a small one
and keep the full size one behind the seat broken in half just in case
pajsh
posted on 6/9/07 at 03:49 PM Reply With Quote
Bent aluminium brackets as previously although the bolts double up to secure the nose cone.
Plate has been trimmed slightly to fit better (about 30mm of each end)
Sorry about the BIG picture.
Front DS Apr 07
Front DS Apr 07
I used to be apathetic but now I just don't care.
rpm
posted on 6/9/07 at 05:47 PM Reply With Quote
mines been trimmed down but the letterings the right size, fixed by spacing off with 15mm copper tube cut at an angle to suit the nose cone and then bolted thru
[Edited on 6/9/07 by rpm]
Marlon
posted on 6/9/07 at 06:44 PM Reply With Quote
Me Also, mine is stuck down the back of the passenger seat with some dirty looking doublesided tape on it, Never had any bother from mr plod although i've only been on the road fo about four months.
If I do ever get pulled I'll say that I hit one of those high speed bumps that I passed a while back!
john
Band Anyone?
Linky to SWMBO 's band
Linky to Brother in laws band
MKoc 1081
roadrunner
posted on 6/9/07 at 06:50 PM Reply With Quote
I have a stikky one, no problems so far.
front pass side
front pass side
[Edited on 6/9/07 by roadrunner]
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 6/9/07 at 06:51 PM Reply With Quote
I trimmed my down but it still has the legal sized border around the lettering (regulations found on DVLA website)
Its then riveted directly to the nosecone
locoboy
posted on 7/9/07 at 11:00 AM Reply With Quote
decided to go with the numberplate in the footwell and dirty sticky tape on it
Took it out last night for 20 odd miles and its a real blast, need to get it into the garage tonight to put a spanner round the critical parts befor i go out again.
Locoboy
Simon
posted on 7/9/07 at 07:00 PM Reply With Quote
See left
Screwed diectly to nose.
Simon
