Author: Subject: Is this SVA ok?
nib1980
posted on 17/9/07 at 09:12 AM Reply With Quote
Is this SVA ok?
Hi all,
I'm now going over the car with a fine tooth comb to check it's OK for SVA.
I wanted to check if this is ok for sva this is my current boss, on a collapsible sierra column, does the boss need to colapse too
many thanks
snapper
posted on 17/9/07 at 09:15 AM Reply With Quote
Mountney steering wheel pad will be enough, probably wont pass without the pad.
I eat to survive
I drink to forget
iank
posted on 17/9/07 at 09:20 AM Reply With Quote
Bad news being you can't buy the pads anymore (rumour has it the mould was wrecked and wasn't being fixed/remade).
Anonymous
graememk
posted on 17/9/07 at 09:31 AM Reply With Quote
panic not dear sir, the wheel i'll lend you comes with pad and boss, flak and paradoxia have both used it from this site with no probs.
[Edited on 17/9/07 by graememk]
ReMan
posted on 17/9/07 at 11:17 AM Reply With Quote
However, no the boss does not specifically ned to collapse....
nitram38
posted on 17/9/07 at 01:39 PM Reply With Quote
Found these pads on ebay:
Mountney
Mountney in packet NTDWM
[Edited on 17/9/2007 by nitram38]
DarrenW
posted on 17/9/07 at 02:43 PM Reply With Quote
i can only comment ref my SVA experience at Gosforth. i fitted aftermarket wheel for retest (long story) and had to fit collapsible boss. He already said that if i brought the car back without one he would fail me.
That is not to say that others have passed with same boss as in pic though - may be a regional interpretation.
posted on 17/9/07 at 03:43 PM Reply With Quote
Mine's same as that and all I had to do was cover the 6 screw heads.
posted on 17/9/07 at 05:43 PM Reply With Quote
Can you not leave the Sierra wheel on for SVA?
nitram38
posted on 18/9/07 at 04:43 AM Reply With Quote
As long as you have angle changes in your UJ's or a collapsable colomn, then it should pass without the boss
DarrenW
posted on 18/9/07 at 08:15 AM Reply With Quote
i had angled UJ's and std Sierra collapsible Boss and SVA man still insisted on collapsible boss if i fitted anything other than std Ford type approved steering wheel. As said might be a local thing so could be worth checking your local VOSA station for definitive answer.
The reason i was given is that the full steering system is type approved and replacing any part of it negates that - hence aftermarket collapsible boss needed. I have however heard of other places getting away with std mountney type boss as long as the wheel itself complies with the rules. My man also said the wheel itself cannot have slots on the spokes and the external rads must comply (2.5mm i think but check the book).
nitram38
posted on 18/9/07 at 08:57 AM Reply With Quote
Mine passed at Mitcham with just two direction changes on UJ's. I even pointed it out and Michael said that either that or collapsable column was fine.
Strange how different testers see things.
[Edited on 18/9/2007 by nitram38]
