mistergrumpy
posted on 29/10/07 at 03:08 PM |
Side Repeaters
Okay I'm being a little lazy here, I've had a quick flick through the book but can't be bothered reading too much into it. I just
wanted to know if side repeaters i.e. indicators on the side of the scuttle or around that area are an SVA requirement or not.
graememk
posted on 29/10/07 at 03:11 PM |
mine are on the back of the headlights and passed ok
mistergrumpy
posted on 29/10/07 at 03:14 PM |
Aye but can you get away with just the rears and front ones only?
posted on 29/10/07 at 03:18 PM |
No, you do need side repeaters, but there are special concessions for 7-style cars - something along the lines of "they must be clearly
visible" or some such generality.
On my car I worked on the principle that wherever I stood to the side of the car I could see at least one indicator.
HTH
[Edited on 29/10/07 by David Jenkins]
mistergrumpy
posted on 29/10/07 at 03:21 PM |
Sorted, thanks. I can look at running some wires in for them then.
iank
posted on 29/10/07 at 03:24 PM |
If you use the jcb lights they have a front and side lens so you don't. Otherwise you do, scuttle is probably the easiest place for most.
Anonymous
