smart51
posted on 9/11/07 at 10:07 AM |
manually adjusted drum brakes
Are manually adjusted brakes allowed on the front axle in an SVA test? I've heard that they're not allowed. Can someone look up in an
SVA manual to see if it is specifically banned?
I've looked it up in my MSVA manual and it doesn't mention it at all. I've phoned my local MSVA test station and the guy said
"umm, err..." When I said that it wasn't mentioned in the manual at all he said that they have to follow the manual and can only
fail things according to the manual so manually adjusted brakes are probably OK". I'm not convinced by his reply.
If the SVA manual states that they cannot be used then I'll be happy. If it doesn't and they are still banned then I'm worried.
matt_claydon
posted on 9/11/07 at 10:44 AM |
From the car SVA manual:
16.2g
Check each brake assembly incorporates an adjustment capability to compensate for friction material wear. On a front axle of a vehicle (other than a
three wheeled vehicle) this must be provided automatically.
If you're putting in for MSVA surely it doesn't matter what the SVA manual says?
[Edited on 9/11/07 by matt_claydon]
smart51
posted on 9/11/07 at 11:04 AM |
quote: Originally posted by matt_claydonquote:
On a front axle of a vehicle (other than a three wheeled vehicle) this must be provided automatically.
Thanks matt. No, it doesn't matter what the SVA manual says per se. If the SVA manual prohibits it and the MSVA manual doesn't then I
know I'm in the clear. better than that, your quote from the SVA manual excludes 3 wheeled vehicles anyway. Brilliant.
thanks again.
iank
posted on 9/11/07 at 12:52 PM |
Did you get my email regarding the mods on mini rear backplates?
Looks like you're good to go with that plan now
Anonymous
smart51
posted on 9/11/07 at 12:57 PM |
Got the email - thanks.
I'm now good to go with 2 provisions. I get the design to a place where I think it will work. I speak to the wife without getting my head
ripped off.
[Edited on 9-11-2007 by smart51]
