Author: Subject: Good fail at Southampton
chrsgrain
posted on 12/11/07 at 02:02 PM Reply With Quote
Hi all,
Well - eventually managed to get to an SVA test! Knew it would fail, but just didn't have time to sort all the problems, what with moving house and everything.
Despite some of the horror stories about Southampton, the tester - Andy was really really helpful and did everything to get it as near to passing as possible;
Failed on...
A few sharp bits I missed, could have fixed those then if thats all it was.
Brake balance bar needs welding / rollpinning
Steering column needs a bit more support, about the only thing which is a bit of a bugger
Speedo needs to work! Hopefully something simple!
Thanks to all on here who helped get it this far, especially NSDev and also Calvin - wherever he is!
Chris
DarrenW
posted on 12/11/07 at 02:50 PM Reply With Quote
Thats not too bad at all. Very close indeed, defo a good fail (in a nice way).
Wont be long now if thats all you have to do. Fingers crossed for retest.
twybrow
posted on 12/11/07 at 04:30 PM Reply With Quote
When you say the column needs additional support, is there any chance you can post a pic of the current failure?
Otherwise a good fail indeed! Good luck for the retest.
posted on 12/11/07 at 05:34 PM Reply With Quote
I had Andy for my test - top bloke!
Sounds like a very reasonable first stab at it and not too difficult to resolvse other than the steering column issue. I would be speaking to Dax to see if it's a known issue and whether they have a fix.
