Author: Subject: stem mirror
barrie sharp
posted on 1/10/03 at 07:21 PM Reply With Quote
stem mirror
hi has anyone got through sva with a stem mirror mounted on the scuttle as a rear veiw mirror with no wind shild just the mirror
thanks for your time
barrie
the cars looking good" a blind man would be pleased to see it"
''stop press'' the blind mans seen it said "it felt ok"
Mark H
posted on 1/10/03 at 07:28 PM Reply With Quote
Have a word with Wadders mate - thats his set up. (u2u him!). Looks good too.
Mark
Mark Harrison and
Q986 KCP back from the dead...
theconrodkid
posted on 1/10/03 at 07:55 PM Reply With Quote
mine did,just a screw it to the roof aFAIR TURNED UP SIDE DOWN
who cares who wins
pass the pork pies
posted on 1/10/03 at 10:12 PM Reply With Quote
Are you fitting 2 wing mirrors? You may not need a centre mirror if you are. I fitted one of the little chrome ones and you can only just see between the seat backs and the roll bar, bit of a waste really.
yours, Pete.
CairB
posted on 2/10/03 at 12:02 PM Reply With Quote
Pete,
I don't have the manual to hand but from memory I'm pretty sure that the interior mirror was mandatory with minimum size and a % rear view, unless there is a solid wall that it can't see through.
Colin
locoboy
posted on 2/10/03 at 12:11 PM Reply With Quote
Correct,
Min Req is one interior (not Vanity!) and one Off side.
If there are internal bulkheads thet will block any rearward vision then one is not required.
Must be marked appropriately and have mouldings round edges.
Adjustable from the driving position
40mm High by 80mm wide (reflective surface not ege to edge.
Hope this helps.
Locoboy
barrie sharp
posted on 2/10/03 at 12:29 PM Reply With Quote
Thanks for the replys but on the subject of 'must be marked appropriately' what does this mean ? I have checked my own car and there are no markings on that and the new mirrors i have brought have no markings.am i missing something?
also my mirror seem small but i guess at 55mm by 105 mm they must be ok
thanks all for your time
locoboy
posted on 2/10/03 at 01:02 PM Reply With Quote
The guidelines state:
" all mirrors must cary an acceptable approval mark, E, or e together with I on a class one interior mirror or III for a class two exterior mirror"
Pick out of that what you will, i cant figure it out.
Locoboy
posted on 2/10/03 at 06:06 PM Reply With Quote
I have aftermarket bike mirrors (ZXR400)fitted which are not E marked and the tester said at SVA (3 years ago) that the two wing mirrors were adequate without the centre mirror but as it was fitted it was tested for edge compliance but not viewing. As far as he was concerned it was purely cosmetic.
yours, Pete.
locoboy
posted on 3/10/03 at 08:33 AM Reply With Quote
"As far as he was concerned it was purely cosmetic"
Is that the application of
Locoboy
andyd
posted on 5/10/03 at 12:08 PM Reply With Quote
See my posts about Norwich SVA answer in this previous thread http://www.locostbuilders.co.uk/viewthread.php?tid=6363
[Edited on 5/10/2003 by andyd]
