Jasper
| posted on 29/1/08 at 02:55 PM |
Are aircraft style ignition switchs SVA ok?
Are these switch's ok for SVA if it open view (ie not behind steering wheel)
| posted on 29/1/08 at 02:58 PM |
i don't the cover will meed the radiussing requirement.
Miks15
| posted on 29/1/08 at 03:04 PM |
arent the covers on those removeable?
If so cant you just add them post SVA?
then there shudnt be a problem unless ofcorse the switches them selfs arnt radiused enough like said?
| posted on 29/1/08 at 03:10 PM |
Plain toggle switches will fail. The covers don't really change much as their edges also fail radius testing.....
Sorry
Best option is either to try and use a cheap and nasty SVA friendly switch until after SVA or even make up a minimalist dash with the bare minimum of
dials and SVA friendly switches and then change it immediately afterwards....
| posted on 29/1/08 at 03:23 PM |
^^^ hes, the toggles would fail too if the caps are removed.
... but by placing the swtich in the steering wheel exempt zone you can fit wahtever spikey things you want. -
JAG
| posted on 29/1/08 at 03:29 PM |
The bare toggle switches will pass IF you fit the small waterproof covers on them.
These are like black condoms with a metal, threaded insert on the base. They fit over the toggle and screw onto the exposed thread at the base.
I fitted bare toggle switches with the aircraft style covers but placed them within the exempt area - it was quite a big exempt area because I kept
the original Sierra steering wheel for SVA
Justin
Jasper
| posted on 31/1/08 at 12:31 PM |
Thanks guys, I'll get a waterproof cover for it then as I don't want it behind the steering wheel .....
